Bob Pau
Guest
Hello Ken, > > I have difficulties to reply from the website you attached below, so I > do it here. > > LSSP is originally for matching purpose, because s11 and s22 is major > parameters determines operation point of PA. Also the harmonics > distortion, and most important, the output power. > > Since you can measure S-para of PA at high power level directly, then > we use an indirect format to measure S11 and S22, in this way, s21 and > s12 is not measured. Actually, S21 is wrong anyway (or not valid) in > testbench measurement. > > The indirect measurement is connect PA input and output with two > slotted line stub, (it behaves like our port-Adaptor), then we tuned > two slotted line to different power level, and then disconnect the > slotted line, we measure the slotted line instead. On end of the > slotted connected to source is terminated to 50Ohm, the other end of > slotted line which is connected to the PA is actually s11*. We do the > same thing for output. > > Since PA Z0 is usually working below 10 Ohm, so that the Smith chart > is actually normalized to 10 Ohm or PA Zo instead of 50Ohm. > > The beauty of smith chart is only A Z-plot, but also a Reflection > coefficient plot, and VSWR plot. > > The input and output impedance of PA is determined in this way. It > cannot use to do stability or other small signal S-para features. Of > course there is way to extract the linear S-para from Non-linear one, > but no body do that. > > The modern application of LSSP is mainly for modelling of PA (input > and output Impedance modulated the behavior of PA) and give a clue of > ACPR and IM3, because you can find a sweet spot of input and output > matching condition that product maximum power, highest PAE and minimal > distortion (ACPR), etc. > > To understand more, you can search MTT-S proceeding, conference, there > are lot of stuff on this topic. Following I attach one for you. > (loadpull a.k.a. LSSP)
