Apr 25th, 2024, 3:38pm
Phase error simulations of a QVCO using Spectre (Read 3314 times)
Ali Fard
Guest
Jul 14th, 2003, 11:56pm
Hi, I was wondering if anyone has any suggestions regarding the phase error simulations using spectre in Cadence. Are there any simpler way of simulating the phase error of a QVCO and getting an approximative number of the error? Or shall I just use the calculator like the old-fashioned way?
Undecided
  IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Phase error simulations of a QVCO using Spectr
Reply #1 - Aug 17th, 2003, 3:10pm
Do you have SpectreRF? If you are designing VCOs you should. Anyway, with SpectreRF it is easy. Simply use PSS analysis to compute the steady-state behavior. By default it computes the magnitude and phase of each signal, so you can simply subtract the phase of the output signals to determine their phase difference.
- MM -
