Guneet,
From the error messages, I would guess that you have an INCLUDE or a SOFTINCLUE in your cds.lib file which is including an hdl.var file. That's not the correct thing to do. An hdl.var file (whilst similar syntax) needs to be kept separate from the cds.lib file.
I managed to get similar error messages by doing the above.
You didn't actually post your cds.lib file, so it's hard to be certain, but this seems a likely explanation to me.
Also, AMS20 is a rather early version of AMS Designer, and I'd definitely recommend moving to a newer one (e.g. LDV51) if you can. Things have moved on a lot in AMS Designer.
