Apr 18th, 2024, 10:51am
spreading spectrum pll (Read 5186 times)
Dze
Guest
Jan 16th, 2004, 7:35am
I would like to use the spreading spectrum technique on a pll. I have access to its VCO input and of course to the reference clock (crystal).
What should I put between the reference clock and the VCO input in order to spread the spectrum?
A simple capacitor did not manage it.
Thanks a lot,
Dze
  IP Logged
Eugene
Re: spreading spectrum pll
Reply #1 - Jan 20th, 2004, 11:27am
Are you asking about a fractional-n synthesizer? Here, the divider ratio dithers about the desired ratio, which no longer must be an integer. The dither pattern is designed to push the phase noise out to high frequencies where the loop filter can remove it. There are lots of papers and books on the subject. Just search for "Fractional N Synthesizers".
Dze
Guest
Reply #2 - Jan 21st, 2004, 1:21am
It's not about dividing frequencies.
I have a clock (HF) in my microcontroller that is obtained from a pll that multiplies a reference crystal clock frequency.
I would like to use the so called "spectrum spreading" in order to modulate the clock (HF) with the low frequency, reference clock (from the crystal). The result should be that when I look at the spectrum of the HF clock (output of the pll), there would not be narrow spike at the HF, but a larger band with a smaller dB value.
I tried a low cost solution, by just inserting a capacitor but it creates only 2 additional smaller spikes in the spectrum around the HF one, while the HF is unchaged. And it creates instability in locking the pll. So I need another solution, low cost, if it exists. ???
Dze
  IP Logged
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Reply #3 - Jan 21st, 2004, 9:52am
I do not understand why you want to spread the spectrum of a microcontroller clock (EMI perhaps), but you can probably accomplish it by injecting noise either before or after the loop filter. The noise could be in the form of a digitally generated dither sequence, or perhaps it could be amplified device noise, perhaps avalanche noise from a zener diode. You could filter it to get the desired spreading spectrum.
Jitter Man
Dze
Guest
Reply #4 - Jan 22nd, 2004, 6:57am
Thanks for your answer. You're right. It's indeed for EMI purpose.
It makes sense to try with some filtered noise. If you have already tried it, did it create any pll instability? I guess it will be a trade off on the coupling capacitor value.
I'll let you know if it worked.
Dze
  IP Logged
