Mar 28th, 2024, 4:15am
[question] Spectre simulation (Read 3618 times)
sim
Mar 09th, 2004, 1:37am
What's wrong  with my simulation?
For exmaple:
Model----ideal-opamp.scs ideal-opamp.va
input command ----- spectre ideal-opamp.scs
spectre compeles with 0 errors,0 warnings, and 0 notice
generate one dir-ideal-opamp.raw,it contains two files
freqResp.ac  and logFile
open results browser, select freqResp.ac, I can not see the waveform  in the waveform windows. why?
August West
I'll get up and fly
away
Re: [question] Spectre simulation
Reply #1 - Mar 9th, 2004, 3:14pm
From within the results browser, once you navigate to the results directory, you must middle click on the mouse and select "Create ROF". This creates the "Run Object File" from the logFile, which describes the results to the results browser. Without it, the results browser does not treat the .ac file as a results file.
-August
sim
Reply #2 - Mar 9th, 2004, 8:22pm
thanks for your reply!
Reply #3 - Mar 10th, 2004, 2:04pm
If you're using IC50 or later, you might also want to
consider using the new waveform tool "wavescan".
It doesn't (yet) support all analyses, but will read
dc, ac, and transient analyses right now - other analyses
(such as RF analyses) coming soon.
