Apr 25th, 2024, 4:56pm
Is timing important for pipelined ADC? (Read 2405 times)
potter
Mar 18th, 2004, 10:09am
??? 1. Why non-overlap clk ? first i designed full system of pipelined by ideal opamp, and switches but real comparators. I use 2 V supply so i set switch threshold 1V.  It OK with ideal comparator and one stage simulation, but when i use my real comparator and connect the secound stage there is something wrong with the output of the first stage.  The first time i guess that may be cause Cparacitic of the comparator of the next stage so i test by simulate with C load and switch but it not the problem. Who know my problem please introduce me something.  :-[
i use simple 2.5bit switched capaciter circuit .
