Apr 24th, 2024, 6:51pm
How to define my own functions in calculator? (Read 5514 times)
stephen
Mar 18th, 2004, 1:08pm
How to define my own special functions in the calculator? I know from the manual that it involves writing skill code. But I don't see where I shall put the skill code. Anybody knows?
Thanks.
Re: How to define my own functions in calculator?
Reply #1 - Mar 21st, 2004, 12:51pm
Here's a simple example:
(procedure (abCalcDoubleCB)
  (calSpecialFunctionInput 'abCalcDouble nil))
(procedure (abIndepVarCB)
  (calSpecialFunctionInput 'abIndepVar nil))
(procedure (abCalcRegister)
  /* register my own functions */
  (calRegisterSpecialFunction
   (list "double" 'abCalcDoubleCB))
   (list "indepVar" 'abIndepVarCB))
  t)
; now call the registration function
(abCalcRegister)
The code should be in a file, when you can then load
from the  .cdsinit file (see documentation on that file)
using:
(load "/path/to/the/above/file.il")
stephen
Reply #2 - Mar 21st, 2004, 11:32pm
Thanks for your reply. I suppose I still have to write a file to put the code for function abCalcDouble, right? When I test this code, cadence complaint that this function is undefined.
So where shall I put the code the function abCalcDouble?
What I actually need is an enhancement to the rms function. The rms function doesn't subtract the DC value first. So I need sth like rms(x-average(x)). Since I do this many times a day, I want to define a special function for it. I don't understand the syntax of skill code very much. It looks like a rule definition language instead of a programming language like C. Can you possibly offer a code example for the RMS function that I need?
Thanks again
[quote author=Andrew Beckett  link=1079644139/0#1 date=1079902314]Here's a simple example:
  t)
(abCalcRegister)
using:
[/quote]
Reply #3 - Mar 22nd, 2004, 1:35am
Stephen,
Whoops, in cut and pasting the code, I missed out one of the
functions in my example. Here it is:
(procedure (abCalcDouble arg1)
  (times arg1 2))
SKILL is a full-featured programming language. Essentially it is LISP, although it can be written with a C-like syntax. The above examples were all written with a LISP-like syntax (that's my personal preference, but it makes no difference to how the code works)
To write it in C-like syntax, you could do:
procedure(MYrms(x)
  rms(x-average(x))
procedure(MYrmsCB()
  calSpecialFunctionInput('MYrms nil)
procedure(MYregisterCalcFuncs()
  calRegisterSpecialFunction(
    list("MYrms" 'MYrmsCB)
; call the function to register the MYrms func:
In fact all the calculator does is build a SKILL expression - you'll see that the definition of MYrms() above uses exactly the expression you mentioned.
More information can be found on SKILL by reading the SKILL Language User Guide in cdsdoc - this is written in the style of a book on a programming language, much as you'd find in a bookshop.
monglebest
Austin
Reply #4 - May 16th, 2018, 11:57am
I am reading the
Cadence SKILL Language User Guide
Product Version 6.1.6 January 2015
but cannot find any keyword starting with calRegisterSpecialFunction, calSpecialFunctionInput, calCreateSpecialFunction or related with calculator.
I also checked
Virtuoso Design Environment SKILL Reference
Am I refer to something wrongly?
Reply #5 - May 19th, 2018, 12:46am
That's because it's in the Virtuoso Visualization and Analysis XL SKILL Reference manual.
If you had just run "cdnshelp" from the command line or use Help->search box at the top in the CIW, or Help->User Guide (say) and then use View->Show Navigation and then search there, you'd find it.
Note that in IC617 there's no longer a need to register functions this way - you can use the "fx" button in the function panel in the ViVA calculator to add your own functions - all you need is a file with the main code that does the work - the UI and registration is handled within the calculator itself.
