Apr 19th, 2024, 5:42pm
Noise Figure measurement of the Receiver (Read 5704 times)
wccheng
May 24th, 2004, 12:29am
Dear all,
      I have a simple receiver which is included LNA, downconversion mixer and the VCO.
      Do I need to add the low pass filter at the IF output for the noise figure measurement?
      How could I measure it in order to get the correct noise figure result?
wccheng ???
Itay
Guest
Re: Noise Figure measurement of the Receiver
Reply #1 - Dec 24th, 2004, 12:18pm
Sure, you have to add it to the total noise figure. The noise figure of a passive element like filter or attenuator is equal to its loss (only with absolute value). You can measure it with VNA (Vector Network Analyzer) and add it to your measurement. You can calculate the total NF result by using Frii's formula:
NFtot=NF1+NF2-1(G1)+NF3-1/(G1*G2) etc..
Good luck,
Itay
  IP Logged
Reply #2 - Jan 25th, 2005, 2:23am
Whether you have to put LPF after mixer or not, it depends on IF spectrum purity.
If IF output have much undesired spectrum than desired IF spectrum(e.g. local leak which have generally large power leak), an input of NF meter will be over loaded, then you can't measure NF correctly.
milkdragon
RF idiot
Reply #3 - Sep 1st, 2005, 5:26pm
You can use the Y-parameter measurement.  Simply apply a noise source at the input, turn the noise source on and off to see the difference of the noise floor from the spectrum analyzer, record also the ENR of your noise source, then you can get the NF
LPF is not a must, but your receiver chain has to have high gain, or otherwise it would introduce error
View Profile milkdragon   IP Logged
