You don't give a whole lot of details, but yes, that would be the right thing to do.
What do you have on top? Schematic or netlist? It doesn't necessarily matter though...
What you can do is to compile the verilog code into your library:
ncvlog -ams -work yourLibName -use5x code.vams
Then in DFII create a config view (File->New->CellView, choose "Hierarchy Editor" as the tool), and configure the top cellView (be it verilog-ams code or a schematic), and then use the Plugins->AMS in the hierarchy editor to set up the simulation and run from there.
Or you can use the standalone "amsdirect" command to create the netlists, and then compile yourself. Easier still, you can use the standalone "amsdesigner" command to do all the netlisting, compilation, and run the simulation.
