Apr 25th, 2024, 9:47am
AHDL (verilog-A) model (Read 2509 times)
jimmy
Dec 01st, 2004, 12:48pm
I found Verilog-A or AHDL models from ahdlLib all resets their outputs to zero at begining. Can I turn off this resetting?
thanks,
jimmy
Re: AHDL (verilog-A) model
Reply #1 - Dec 1st, 2004, 10:01pm
This isn't true for all components in ahdlLib. Not all outputs will be zero at time zero. It depends on the DC solution.
Yes, they will probably start at 0 when trying to find the DC solution (but then so does every node in the circuit).
Without some specifics it's impossible to answer your question. It may be that the code needs modifying to do something different on an @initial_step or it may be that you need to do a nodeset, or it could be something completely
different altogether.
Please ask a more specific question, with an example, perhaps?
