Apr 24th, 2024, 11:20pm
how to distinguish frac spur and ref harmonic (Read 2416 times)
liliwang
Guest
Dec 26th, 2004, 6:46pm
In a frac-N pll using 2rd orfer sigma-delta, when there is a strong spur neer carrier, how to distinguish it is a fractional spur or just reference harmonic.
What's the cause of reference harmonic, and how to reduce it.
  IP Logged
DaveB
Re: how to distinguish frac spur and ref harmonic
Reply #1 - Jan 5th, 2005, 7:52pm
If it's at the reference frequency that's a strong hint. If you change channels and the spur stays at the same frequency offset, then it's likely a reference spur. If you change frequencies, and the spurious offset changes, then I'd suspect some sort of fractional spur.
Dave
