Apr 24th, 2024, 12:26pm
Assura lvs problem under linux (Read 1261 times)
stephen
Feb 13th, 2005, 11:47am
I often parameter mismatches when doing LVS with Assura under Linux (Fedora core 2). It keeps reporting parameter mismatch errors of a very tiny percent (like 1e-7 percent). I don't think it's a problem of my layout. Instead, it should be the problem of Assura handling floating-point number incorrectly under linux.
Any ideas?
Thanks.
Re: Assura lvs problem under linux
Reply #1 - Feb 13th, 2005, 9:34pm
Most rule decks would do LVS comparison with a tolerance to avoid this sort of thing (not just for Assura, but for all physical verification tools). Floating point rounding errors are inevitable with IEEE floating point arithmetic, and so doing exact comparison of calculations done from different source data is asking for trouble.
stephen
Reply #2 - Feb 14th, 2005, 8:39am
I see your point. But the same version of cadence works all right under unix without this kind of error. Also we have never met this kind of error before in Diva.
[quote author=Andrew Beckett  link=1108324028/0#1 date=1108359273]Most rule decks would do LVS comparison with a tolerance to avoid this sort of thing (not just for Assura, but for all physical verification tools). Floating point rounding errors are inevitable with IEEE floating point arithmetic, and so doing exact comparison of calculations done from different source data is asking for trouble.
[/quote]
Reply #3 - Feb 14th, 2005, 9:12am
Either way, I wouldn't consider that a tool bug. There are quite likely to be differences in floating point calculations between different hardware platforms. By luck you've not hit this problem before (probably because all the testing was done on another platform), but it is dangerous to rely on exact matching of floating point numbers, IMHO.
I've not seen any reports of similar problems with Assura, so I doubt it's a tool bug.
stephen
Reply #4 - Feb 14th, 2005, 9:43am
I guess the right way to do is to modify the rule to add a little tolerance. I checked the rule and it seems I have to modify many lines, like resistance tolerance, mos tolerance, capacitor tolerance, etc. Is there any general tolerance which controls all the devices?
[quote author=Andrew Beckett  link=1108324028/0#3 date=1108401131]Either way, I wouldn't consider that a tool bug. There are quite likely to be differences in floating point calculations between different hardware platforms. By luck you've not hit this problem before (probably because all the testing was done on another platform), but it is dangerous to rely on exact matching of floating point numbers, IMHO.
[/quote]
Paul
Switzerland
Reply #5 - Feb 15th, 2005, 11:39pm
Stephen,
usually resistor and capacitor tolerances are not set to 0, because the schematic tool and the simulator have a more elaborate way of calculating the value (like taking into account resistivity of the poly contacts etc.). So you probably only have to change the transistor tolerances which are set to 0. The number of concerned rules should not exceed 10 in a mixed-mode technology. Be careful not to reduce tolerances related to transistors of standard cells, they usually do not have perfect match and this could lead to a large number of "false" errors.
Good luck
Paul
