Apr 20th, 2024, 1:16am
Problem in installing Assura in ace446 (Read 4435 times)
rpaul
IIT Kgp
Nov 04th, 2004, 11:24am
I am having problem is installing Assura in my ace446.  The assura icon is not coming in the Virtuoso Layout Editor Window. Can any one guide me in its installation or can refer me to some sites regarding it.
Re: Problem in installing Assura in ace446
Reply #1 - Nov 4th, 2004, 10:50pm
I'm assuming ace is your environment name? It's not a Cadence tool name.
What you need to do is:
a) Install an Assura version intended for use with IC446
    rather than IC50. There are separate builds - you can
    see this on the http://downloads.cadence.com site
b) Make sure that the ASSURAHOME environment variable is
    set and is pointing to the root of the Assura installation
    tree.
c) Make sure that $ASSURAHOME has the tools link pointing
   to tools.sun4v (or whatever platform you're using).
d) Make sure your UNIX path contains:
    $ASSURAHOME/tools/assura/bin
That should be sufficient.
Of course, I don't know whether "ace446" is altering the path or environment variables itself - you'll have to check that.
rpaul
IIT Kgp
Reply #2 - Nov 8th, 2004, 10:59am
Thank you Andrew for the suggestions. I
