Ray_Lin
Taiwan
Dear All: I have a symmetric inductor with 3 terminals(Plus, Minus, and Common-mode), for the loading of a differential circuit(a Mixer). Plus and Minus nodes are with the metal 5, and Common-mode node is with metal 3. The Common-mode node can be easily specified in different CAD tools such as Diva and Dracula due to its different metal connection. But the Plus and Minus ndoes are not so due to their identical connection metal layer. In DRACULA LVS, I can specify one of the two identical nodes as Plus node by a dumy layer. But I can not do so in Diva LVS command file because dummy layer cause other LVS problems. Does anyone know how to specify each terminals of 3-terminal inductor in Diva LVS command file??
