Apr 19th, 2024, 10:26pm
Specify Terminals of a 3-terminal Inductor (Read 4116 times)
Ray_Lin
Taiwan
Mar 29th, 2005, 8:14am
Dear All:
     I have a symmetric inductor with 3 terminals(Plus, Minus, and Common-mode), for the loading of a differential circuit(a Mixer). Plus and Minus nodes are with the metal 5, and Common-mode node is with metal 3. The Common-mode node can be easily specified in different CAD tools such as Diva and Dracula due to its different metal connection. But the Plus and Minus ndoes are not so due to their identical connection metal layer.
   In DRACULA LVS, I can specify one of the two identical nodes as Plus node by a dumy layer. But I can not do so in Diva LVS command file because dummy layer cause other LVS problems.
   Does anyone know how to specify each terminals of 3-terminal inductor in Diva LVS command file??
View Profile Ray_Lin Ray_Lin   IP Logged
Re: Specify Terminals of a 3-terminal Inductor
Reply #1 - Mar 29th, 2005, 8:53pm
If anything I would expect this to be easier in Diva than Dracula. Dracula only supports fixed types of devices, with fixed numbers of pins. Diva is flexible about device types and the number of pins of each.
So I see no reason why there should be any problem with doing this in Diva.
Without seeing the rule deck and layout, it's hard to say exactly what is going wrong - your description was rather vague as to the problem itself with Diva.
Ray_Lin
Taiwan
Reply #2 - Apr 7th, 2005, 1:54am
Thanks, I've solved this problem by label text.
