Apr 23rd, 2024, 7:43pm
how to introduce model name in create netlist (Read 5571 times)
jay_lin
big capacitor
Jun 06th, 2005, 6:38pm
Dear all,
When I draw the schemaitc I appoint the model name "NE" for a high voltage NMOS in the object properties, but when I use the "CDL" to create the netlist, all the "NE" are replaced by "NM", because the special NMOS transistors are so many that I don't want to change them one by one, is there any easy way to introduce the model name?
Jay
Re: how to introduce model name in create netlist
Reply #1 - Jun 6th, 2005, 9:13pm
For your primitive component, if you look at:
Tools->CDF->Edit
enter the library name/cell name of the mosfet (or use the browser). Note, if you're going to change the component, you'll need to set the CDF Type to "Base" rather than Effective.
Then scroll down to the simulation information section. Hit the Edit button in that section, and change the simulator cyclic to "auCdl". You'll see something called "instParameters" there. If you add "model" to the instParameters, it allows you to netlist the model from a CDF parameter called model (which you can use the propMapping for if it is defined as a parameter called something else), rather than using the modelName setting in the auCdl simInfo.
If you want to change all instances of this component, change the modelName in the auCdl simInfo to whatever you want.
This is covered in more detail in the Analog Simulation Help
<instdir>/doc/anasimhelp/anasimhelp.pdf
and the CDF user guide:
<instdir>/doc/cdfuser/cdfuser.pdf
(you could of course look at these using cdsdoc; I just
gave the paths to the PDFs for convenience).
jay_lin
big capacitor
Reply #2 - Jun 6th, 2005, 10:25pm
Andrew,
Thank you very much, I can introduce the model name now under your guide.
Best Regards & HAND
Jay
Jay
