Siva
Guest
Re: Error Message in NCSIM,registers cannot drive
Reply #16 - Nov 14th, 2005, 5:33pm
Hi all, I was getting the error Registers cannot directly connect to analog ports. So used assign c=control; then it is giving "ncelab:*E,CUVNCM : No connection module found need inoutports of continuous discipline electrical,discrete discipline logic. I am using Cadence LDV 5.1 NCSimulator.
Could anybody tell me what the problem is and how to resolve? I really appreciate your help. Thanks in advance.
Siva
verilog-ams CODE for switch :
`timescale 10ps / 1ps `include "disciplines.vams"
module testbench (); electrical gnd; ground gnd;
reg control; logic c;
initial control=0;
always #100 control=~control;
assign c = control;
switch sw0 (p, gnd, c);
vsource #(.type("sine"), .ampl(1.0), .dc(5), .freq(100M)) v0 (vp, gnd); resistor #(.r(10k)) r0 (vp, p); endmodule
`timescale 1ns / 1ps `include "disciplines.vams"
module switch (p, n, s); parameter real ron = 10.0 from (0:inf); // on resistance (ohms) parameter real roff = 100.0M from (ron:inf);// off resistance (ohms) parameter real td = 0.0; // delay time (s) parameter real tr = 20n; // rise time (on -> off) (s) parameter real tf = 20n; // fall time (off -> on) (s) input s; logic s; electrical p, n; real reff;
analog begin @(posedge s) reff = ron; @(negedge s) reff = roff; @(initial_step) reff = (s ? ron : roff); I(p, n) <+ V(p, n) / transition(reff, td, tr, tf); end endmodule
