Apr 19th, 2024, 1:06am
charge pump in veriloA (Read 4223 times)
Monia
Guest
Sep 29th, 2005, 8:08am
I have some problems to model an output current in verilogA expecialy when I have to define an output voltage and a current value associated as in case of a charge pump.
Any suggestions
Monia
  IP Logged
Re: charge pump in verilogA
Reply #1 - Sep 29th, 2005, 10:16am
My suggestion would be that you give sufficient details for someone to have a clue what your problem might be!
Perhaps you could post your model, for example - even if it doesn't work. Together with a detailed description of what you want it to do.
Your question is so open ended, it would be impossible (I'd have thought) to answer it.
jbdavid
Re: charge pump in veriloA
Reply #2 - Oct 2nd, 2005, 5:55pm
Monia.. most of us model the output of the chargepump as a current.. (possibly as a Voltage dependent Current) --
The VOLTAGE on the charge pump output is taken care of by the Loop filter input capacitance and the circuit simulator..
As with ALL circuit simulation tools, you can only specify one or the other.. Voltage or current..
If you want the output voltage to vary with Iout, then you include an output resistance in your model..
(Thevenin Eq. Model)
If you want the output current to vary with Vout, then you include an output resistance in parallel to the output current.. (Norton Eq. model.)
Hope this helps.
jbd
jbdavid
