Apr 18th, 2024, 7:22pm
Differential Interface (Read 4341 times)
Linus
Guest
Nov 15th, 2005, 2:35am
Hi All,
I am looking for different topologies integrating a differential interface with the following requirements:
- differential interface with on-chip 50 Ohm termination
- very small power consumption
- the differential signal provides is switched current source with 5mA. both input lines are externally terminated with 50 Ohms to 3.3V.
- the input frequency is 400 MHz
What kind of topology would be the best as the complete system is very jitter sensitive ?
Thanx for the hopefully incomming answers,
Linus
  IP Logged
Paul
Switzerland
Re: Differential Interface
Reply #1 - Nov 15th, 2005, 12:02pm
Linus,
are you talking about I/O interfaces? If so, did you consider LVDS-type structures?
BTW, for differential signalling you should consider 100 Ohm termination Wink
Paul
Linus
Guest
Reply #2 - Nov 15th, 2005, 11:19pm
..or 50 Ohms termination for each input..
Yes, I am talking of I/O interfaces, and I did look at LVDS interfaces.. But: think for the type of interface I am looking for, this could be an averkill, or ?
My basic idea was: having an nmos source follower with an nmos current source for each input. The gate of the source follower is the input and has an on-chip 50 Ohms resistor to VDD. The outputs of the source follower is connected to a simple differential to single ended comparator.
..but I am looking for alternatives..
Linus
  IP Logged
