Apr 17th, 2024, 10:29pm
Pages: 1 2
question in sigma-delta ADC (Read 4122 times)
chuzi
BeiJing China
Re: question in sigma-delta ADC
Reply #15 - Jan 03rd, 2006, 7:15pm
Dear Sheldon,
   Great thanks to you for your help, I will read it and think about what you said careful. But maybe I didn't get the exact meaning of your last two sentences,always need to run that final simulation and just want to run minimize the number of times you run that two week long simulation. Could you forgive my ignorance and explain the sentences for me again? Thanks again.
   And there is another little question:) My fft result is below:
   The peak signal is above 0dB, my m-file is in earlier post, could you please to tell me how to modify it? Great thanks.
   Best regards!
  chuzi
sheldon wrote on Dec 30th, 2005, 6:54pm:
Chuzi,
  There is a good description of the factors you might
want to explore, at this link
http://www.imse.cnm.es/esd-msd/WORKSHOPS/MIXMODEST/PRESENTATIONS/medeiro1.pdf
Medeiro has done a good job of breaking down the
factors that effect performance.
  Next, you might want to spend some more time
thinking about your overall methodology/strategy
for performing this design, in particular, look at the
stuff that Ken has written about top-down design. My
experience is that using just system level, Simulink,
and transistor level simulation is not going to get
you the result you want in the time you want.
You really need to think about using mixed-level
simulation. You will always need to run that final
simulation. You just want to run minimize the number
chuzi
BeiJing China
Reply #16 - Jan 3rd, 2006, 7:24pm
Hi ZhengHao,
   I delivered the mail again and I am in BeiJing:) That book is expensive for me, and I suggest that you recommand it to the library nearby and borrow it. That is all about 2-1 cascade 1-bit sigma-delta modulator, you could just follow it. Actually my 2-1-1 followed it,too:)
   Best regards!
chuzi
c.h.zheng wrote on Jan 1st, 2006, 8:14am:
hi chuzi:
thanks for your advice,my email add:wwwzhenghao@163.com.could you try again,where are you?i'm  from chengdu,in china.could you tell me where that book can buy?thanks very much.
material
Reply #17 - Jun 4th, 2006, 7:34am
It seems that you forget to divide something.
You can read the paper "Behavioral Modeling of Switched-Capacitor Sigma–Delta Modulators" CAS,March,03
And the source code which can be found in the mathwork website named SDT for reference.
jovial
Reply #18 - Mar 7th, 2016, 10:24pm
Hi Sheldon,
Can you plz forward me the document  since the link does not work .
http://www.imse.cnm.es/esd-msd/WORKS...S/medeiro1.pdf
Pages: 1 2
