This definitely looks like a texting problem. Take a look at the .erc file as well - this will also give some information about the texting. I don't think you should need to use a cpoint file, by the way - but you might want to use *.EQUIV in the CDL netlist to specify the layout to schematic mapping of the nets. By far the best is to use the same names on both sides...
(For anyone else who's reading this, Dracula is the verification tool being used. For jaylin79, it's best to indicate which verification tool you're using - because it could have been one of many!).
