ACWWong
the self resonant frequency is when the imaginary input impedance is zero (ie the L and C cancel/resonate). I think what you are seeing is an artifact the inductor you are likely to be looking at is infact a lumped model consisting of series L, series R and shunt C. Also likely to be included at each terminal is an RC network to substrate. You can look at the configuration in your netlist/modelfile. When you connect one side of the indcutor to gnd, you short one of the RC terminal networks to ground, hence the effective capacitance is changed from if you did the measurement differentially. Now which srf you are interested in (single ended or differential) depends on how you intend to use the inductor in your circuit.
