ahmad_abdulghany
Hello every body, Can anyone give me steps to follow to be able to add a Verilog-A model in ADS2005? I read Verilog-A manuals that came with ADS2005A, and I did the following: - Installing Verilog-A design kit - I wrote my Verilog-A module (e.g. for a VCO.va) - I copied that *.va file in a folder named "veriloga", i created it in my project directory. - I added "Verilog-A load" from "Devices Verilog-A" palette. - From "Verilog-A load" properties, i wrote "VCO.va" in the field: "Module file name" and hitted "add", then OK. Now, I want to know how to do the following: - I want to add, draw, or generate a block that has inputs and output ports like what is in my model, how can i do that? - Is there any method with which i can let ADS generate the basic code of the new component, i.e. the entity or describtion of its input and output ports as well as the "include" lines? How to do? - After I got a "rectangular bloack" that has inside my model, can i see my "parameters" in my model to edit them as i do for any other components? How can i see that parameters? Please reply as soon as possible, Thanks alot in advance, Ahmad
