Apr 25th, 2024, 12:44pm
SAW filter insert loss (Read 5038 times)
cybq
Jul 03rd, 2006, 1:10am
Hi friends,
A problem was found that the insert loss of SAW filter synthesized by ADS is not agreed with the specified value if the input and load impedance are different. Isn't a bug in ADS?  There is several dB difference.
That is to the insert  loss ( measured by the output of SAW filter load divided by the voltage when source and load are direct conected) is agreed with the specified value when in/out impedance are the same.
But, when I simulated the S parameters, setting up the Term1 and Term2 are the source and load impedances respectively, I get the result that the S21 is the same as the specified value. Why?
Thanks in advance.
cybq
Re: SAW filter insert loss
Reply #1 - Jul 3rd, 2006, 8:23am
Hi.
What do you mean by "SAW filter synthesized by ADS" ?
You synthesized the equivalent LCR circuits from measured S-parameter of SAW filter ?
S-parameters are defined by port impedances.
So it is natural that S21 is changed when you use different port impedances from vaules in S-parameter measurement.
ADS have following function.
stos()
Changes the normalizing impedance of a scattering matrix
Syntax
y = stos(S, zRef, zNew, zy)
cybq
Reply #2 - Jul 3rd, 2006, 6:29pm
I have tried to synthesized the SAW filter with LCR, but failed. Because it is not possible to synthesie the SAW high selection characteristics with electronical components, instead of using a SAW (which uses the piezoelectric effect to turn the input signal into vibrations that are turned back into electrical signals in the desired frequency range).
