Feb 16th, 2026, 9:29pm
Transient noise (ELDO) and 'ltf (Read 3051 times)
Visjnoe
Jul 25th, 2006, 5:38am
Following lines of VHDL-AMS code (part of the description of a filter) generate erroneous output waveforms:
vinp_filt == vinp_noisy-0.5*(vinp+vinn);
vinn_filt == vinn_noisy-0.5*(vinp+vinn);
voutp_filt == vinp_filt'ltf(num,den);
voutn_filt == vinn_filt'ltf(num,den);
with vinp_noisy, vinn_noisy being the across quantities associated with the output terminals of a SPICE SUBCKT which includes a noisy voltage source like this:
.SUBCKT noise_gen vin vout
Vnoise vin vout noise 1.6e-17 0 1                  <- ELDO noise source
.ENDS noise_gen
Without the addition of this noise, the code of the filter provided good results (good filtering operation observed).
In combination with the noise generating SUBCKT, a transient noise analysis produces an erroneous filter ouput (DC signal instead of filtered signal + noise).
If I bypass the filtering, so
voutp_filt == vinp_filt;
voutn_filt == vinn_filt;
I do get a nice, noisy+filtered output waveform.
It has to be noted, that when I use the 'ltf statement and the noise generating SUBCKT, the results provided by an AC simulation look OK (inoise/onoise as expected).
Is anybody familiar with this issue and/or knows a workaround?
Kind Regards,
Peter
