Apr 25th, 2024, 5:04am
Measurement of Voh spec for receiver with CMO (Read 2789 times)
dandelion
Nov 01st, 2006, 11:13pm
In many receiver(CMOS/TTL level output)product, it gives the spec of the output high voltage(Voh) as below;
Voh 3.8V-typ 4.9V-max
the test condition above is Ioh=2mA,Vid=+200mv
I drafted the testbench for the above as attached diagram.
I want to know if the current source in th ediagram is used in the test. Someone told me it is replaced by the resistor.
And also, if I want to deisgn a receiver chip, in the design, how can I simulate this spec?Used an ideal current source?
topquark
Thames Valley, UK
Re:  Measurement of Voh spec for receiver wit
Reply #1 - Dec 7th, 2006, 4:21am
Hope you may have resolved this.
Anyway, just trying to see if my understanding's correct:
Voh is the min. o/p level that's read as a logic "high" and Ioh is the current flowing into (a specified) o/p load under that condition, usually it's a capacitive load in case of CMOS.
As for your testbench, i/p conditions are ok but at the o/p you need to just put a variable o/p cap load & simulate.
measure Vout when Iout is 2mA. This will be your Voh.
Hope this's the way you did it.
Gautham
