ACWWong
you need to input just one signal at the image frequency at the RF input, which causes an in-band response in your receiver. The ratio of this image stimulated in-band response versus a wanted input signal response gives you the image rejection.
The input RF image frequency depends on your architecture... for a super-het, it is offset from the LO by the IF (opposite side to the wanted frequency).
