Sep 27th, 2024, 12:32am
Sigma Delta DAC Model (Read 3516 times)
Nibblo
Jun 05th, 2007, 12:38am
Hi there, I am looking to model a 1bit Sigma Delta DAC
using Verilog AMS or similar. Can anyone tell me if
there is a model already available for use with Cadence?
-Nibblo-
adesign
Re: Sigma Delta DAC Model
Reply #1 - Jun 5th, 2007, 1:33am
This is a good start. I'm not sure if it can be used with Cadence.
http://www-mtl.mit.edu/researchgroups/perrottgroup/tools.html
NitinAtCadence
Reply #2 - Jun 27th, 2007, 9:56am
Hi Nibblo,
A DAC model in Vams should not be too difficult, however there is nothing directly available from Cadence. However, the 'bmslib' from Cadence has a model for a behavioral 8-bit DAC, and also a current-steering DAC. These may not directly apply to the Sig-Delta, but it will give you a good idea of where to start.
Reply #3 - Jul 13th, 2007, 6:53am
In 'ahdlLib' from Cadence, there are a first order sigma delta ADC, named sigmadelta_1storder. There are DAC model in 'ahdlLib', too. Please take a look.
Yawei
