Sep 26th, 2024, 10:17pm
referenceless CDR paper/reference? (Read 5384 times)
Visjnoe
Jul 02nd, 2007, 5:02am
Dear all,
does anyone have a good reference to a referenceless clock and data recovery (CDR) implementation,
meaning a CDR with a PD which allows phase and frequency tracking?
I've seen a paper by DeVito but it requires modifications to a standard (2-input) CP...it might be an option, but it would be nice to have a less 'disrupting' PD architecture (thus having a single UP/DOWN output port).
Peter
Visjnoe
Re: referenceless CDR paper/reference?
Reply #1 - Jul 2nd, 2007, 8:12am
Dear all,
in the meantime, I found this paper already:
Dong-Hee Kim and Jin-Ku Kang, "A 1.0Gbps Clock and Data Recovery Circuit with Two-XOR Phase-Frequency Detector",AP-ASIC 2000.
It looks promising, but I don't think their approach guarantees frequency lock with a random (NRZ) data input...
it's just a feeling (has to be verified). There are also no measurement results in there.
Peter
iccc
China
Reply #2 - Jul 10th, 2007, 1:07am
You can refer to Razavi's book-Design of Intergrated circuits for optical communication.Maybe this paper is helpful.
View Profile iccc iccc   IP Logged
Paul
Switzerland
Reply #3 - Jul 12th, 2007, 3:02pm
Hi Peter,
Due to the non-periodic input data, clock recovery cannot use combined phase-frequency detectors. This means that in any case, you need to rely on a frequency acquisition loop operating side-by-side with the phase-locked loop. I don't know the last reference you mention, but some publications focus on the phase loop and omit to talk about the frequency loop.
If you plan to design a reference-less CDR, you may want to have a look at the quadricorrelator topology as a starting point:
http://www.ee.ucla.edu/~brweb/papers/Journals/BRApr96.pdf
Paul
