Berti
Vector-based DEM like CLA, ILA, DWA etc. are easy to model. You basically just need a vector where you store the indices of the unit capacitors and rotate the position of the unit capacitors according to the algorithm.
The book from Steyaert gives an overview over the most common DEM and explains how they work. Yves Geerts Michiel Steyaert and Willy Sansen , Design of Multi-Bit Delta-Sigma A/D Converters, Kluwer Academics, 2002 .
