Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 27
th
, 2024, 12:21pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› Phase margin of PLL from SpectreRF?
Previous topic
Next topic
Phase margin of PLL from SpectreRF? (Read 2510 times)
savithru
Jul 20
th
, 2007, 12:55am
I want to know how I can check the Phase margin of my PLL. I am using the specterRF.
Also is it possible to check/plot the loop gain.
Kindly reply.
Thanks & Regards
SavithRu
Thanks & Regards
SavithRu
IP Logged
Visjnoe
Re: Phase margin of PLL from SpectreRF?
Reply #1 -
Jul 20
th
, 2007, 2:39am
Dear,
I suggest you construct a phase domain model using MATLAB and fill in the device level parameters.
You can also use verilog-A for this of course (I refer to the papers by Ken Kundert which discuss such a model).
Peter
IP Logged
Reply #2 -
Jul 20
th
, 2007, 12:54pm
If the PLL can be directly analyzed in SpectreRF (i.e. if the steady-state solution is purely periodic), then you could also use pstb analysis to check the stability on the actual PLL (rather than building a model).
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
