Sep 27th, 2024, 4:28pm
comparator and pads in a sigma delta modulator (Read 2829 times)
filipe
Brasil
Jul 20th, 2007, 2:15pm
To supply a Sigma Delta Modulator, I have two separated sources: an analog and a digital voltage supply. where should I supply the compartor??? With the VDD from digital or analog Supply??? Why?? Have you some references for this???
And the VDD of the PADs, where should I connect it??? VDDa or VDDd??? Why???
View Profile filipe filipe   IP Logged
Berti
Re: comparator and pads in a sigma delta modulator
Reply #1 - Jul 23rd, 2007, 10:17pm
You need the seperate your circuit blocks into agressors and victims. Since the comparator
decision might be influence by spikes on the supply I usually connect the comparator to
the analog supply (and provide local decoupling to avoid switching noise propagate through
the circuit).
The pad-ring is usually splited in an analog and a digital section (or even more sections
for larger chips). However, if you don't want to split the pad-ring you can still supply the
pad-ring with a seperate supply and provide analog and digital supply directly to the core.
Hope this helps, regards.
filipe
Brasil
Reply #2 - Jul 26th, 2007, 11:59am
Yes, it has been very helpful.
In the case of the local decoupling to the comparator. Should I put a capacitor in parallel with the comparator source??? Which order???
Berti
Reply #3 - Jul 26th, 2007, 10:17pm
For good decoupling you should put a resistor between the sensitive supply and
your comparator supply (the resistors decouples the two circuits). However, often
the speed of the comparator is critical and one cannot tolerate any voltage drop
over a resistor.
Therefore I recommenend to add only capacitance between vdd and gnd. Make
sure that the capacitance is close to the source (in order to keep the switching
noise localy). The capacitance value will depend on your comparator.
