Sep 27th, 2024, 12:18pm
What signal in cables, analog or digital? (Read 1841 times)
reset
Jul 24th, 2007, 8:09am
Hi, I'm designing a transmitter with MIMO capability. I hope to use a separate analog module for RF (maybe also IF), and a digital module for baseband processing. But I'm not sure where to put DACs/ADCs. Digital interface seems to be more reliable, but requires more cables. However, I don't want to put several DACs/ADCs on a single board as they could occupy large areas. Could you pls give me some advice on this?
Thank you!
mg777
Re: What signal in cables, analog or digital?
Reply #1 - Jul 24th, 2007, 9:39am
