Apr 19th, 2024, 8:28pm
Measurement of offset of ADC (Read 4249 times)
babunp114525
Aug 01st, 2007, 9:04am
This is regarding measurement of offset value of ADC.
Can any body tell me whether do i need to consider the value of DNL while calculating offset value.
The standard equation for calculation is offset=Tp(1) - 1LSB where Tp(1) is the 1st transition point of a staircase digital output. Do i need to consider the DNL value of that code while measuring the offset value i.e. is the following equation correct for measurement of the offset error of an ADC?
offset = Tp(1) - 1LSB - DNL ( at code 1)
Please reply me ASAP.
Re: Measurement of offset of ADC
Reply #1 - Aug 7th, 2007, 11:19pm
I don't think you need substract DNL from TP(1).  Normally, the offset are corrected before calculate DNL.
Yawei
babunp114525
Reply #2 - Aug 9th, 2007, 10:24am
hi  ywguo,
you are right that while calculating the DNL, offset is nullified as DNL = Tp[i+1] - Tp[i]. Now, here Tp[i+1] and Tp[i] are having same amount of offset. Therefore, while measuring DNL, offset is getting nullified.
But DNL is present at each and every code. Therefore, can I write Tp[1] = 1LSB width+DNL+Offset?
if this is true, then we need to consider the DNL value while considering the offset, else not. But, I am not sure whether, the above equation is right?
Reply #3 - Aug 14th, 2007, 8:46pm
The above equation is NOT right.  We measure the TP[1] at x-axis, while offset at y-axis. Right?
Yawei
