Sep 26th, 2024, 10:20pm
Adder stage in feedforward SD modulators (Read 2343 times)
HdrChopper
Aug 09th, 2007, 7:26pm
Hi All,
What is the criteria for selecting between a passive adder network vs an active one (with an opamp) in a SD feed-forward topology? I could guess it mainly depends on the coefficients for such stage, it there is one coefficient larger than one the only choice is active. Is this assumption correct? Am I missing something more important to consider?
Many thanks
Tosei
Keep it simple
Berti
Re: Adder stage in feedforward SD modulators
Reply #1 - Aug 28th, 2007, 1:21am
Hi Tosei,
I think whether you implement a passive or an active adder depends on how much signal attenuation
you can accept. With reduced supply voltage, the signal swing in SD modulators has become smaller and
the attenuation of a passive adder cannot be tolerated anymore. Furthermore, the coefficients of a passive
adder are sensitive to parasitic capacitance. An active adder isn't and therefore often results in a more
roboust design.
Thomas
HdrChopper
Reply #2 - Aug 28th, 2007, 9:57am
Thomas,
Thanks for your reply.
Hernan
Keep it simple
