Sep 29th, 2024, 4:24pm
Reference Current Generation (Read 4408 times)
Croaker
Aug 16th, 2007, 7:43am
Hi, is there any way to generate a reference current such that the absolute value does not change as components change?  Let's say you used a bandgap voltage and a resistor to generate a current...if the resistor value values, so does the current.  The goal is to keep the absolute value of the current constant.
Thanks in advance for your brilliant ideas!  :)
aaron_do
Re: Reference Current Generation
Reply #1 - Aug 16th, 2007, 8:33am
You can design a bandgap reference with IPTAT and insensitive to resistor variation. Try searching IEEE xplore for IPTAT reference...
Aaron
MonteCarlo
Reply #2 - Aug 18th, 2007, 6:01am
Unfortunately not. Here are a few options to explore:
Resistor trimming.
Use an off chip resistor.
Switched capacitor resistor (depends on frequency and capacitance).
-Monte
Reply #3 - Aug 18th, 2007, 3:47pm
Croaker,
  One other thought, can you design around the problem at
a higher level of the system? For example, in an integrated
switched-current DAC, you can use the resistor-type for the
reference current generator and the DAC load resistors. Then
the error is reduced to the mismatch between the resistors.
Since the resistors values will track across process, voltage,
and temperature, the overall system looks like it has absolute
accuracy without actually using precision components.
aaron_do
Reply #4 - Aug 18th, 2007, 7:06pm
So sorry about that.
I went back and read the papers i had read before on CMOS BG references and seems i had understood the papers wrongly. Funny though, my BG reference seemed to be iptat...
Aaron
fehler
Reply #5 - Aug 19th, 2007, 6:57am
For resistor trimming, now we are using a very time cosuming solution, that use test machine and I2C interface to adjust.
Is there any better choice?
MonteCarlo wrote on Aug 18th, 2007, 6:01am:
Resistor trimming.
-Monte
Croaker
Reply #6 - Aug 20th, 2007, 2:07pm
Thanks for all the replies!   Smiley
