Best Design Tool = Capable Designers
A 7 GHz ring oscillator?
Instead of obsessing on matching, why dont you AC couple each stage so that matching offset is a non issue? Need to have a startup circuti on the ring, but thats ok.
Or, if you are only coming off one stage of the ring, then matching is a non-issue -
At 7GHz you want minimal parasitics. Jerry
