Sep 29th, 2024, 4:24pm
mismatch problem in the filter (Read 2772 times)
James Bond
Oct 01st, 2007, 12:48pm
I met a wierd problem, in my fully differential all pole chebyshev active filter, when I change one of the matched resistors 0.2%, system phase and frequency respond totally changed, it comes up zero and stop the attenunation in the stop band, which makes my filter away from the specification. Does anybody know the reason? why such small mismatch can affect that much ? and how to solve this problem?
Before mismatch:
James Bond
Re: mismatch problem in the filter
Reply #1 - Oct 1st, 2007, 12:48pm
with mismatch:
Reply #2 - Oct 5th, 2007, 4:19pm
it would be informative if you took and did the pole placements and how they shift due to mismatch.
Some pole-zero constellation placements are  more robust (in spectral response) to shifts than others.
jerry
James Bond
Reply #3 - Oct 6th, 2007, 6:29am
I will post the pole zero simulation diagram later. I am using vcvs from analoglib to model fully differential opamp, could that be a problem? it can not work as a real opamp to deal with the error input I think .
Thank you very much.
