Sep 29th, 2024, 2:16pm
how to reduce the current sinker's noise (Read 2758 times)
Robert
Xiamen city,Fujian PRO. china
Oct 10th, 2007, 6:55am
hi,all
  i am designing a 2.5Gbps Transimpedance Amplifier currently, i utilize the cascode topology, the input impedance is greatly reduce to 1/gm, so the input pole is moved far away, however, i found the current sinker contributes large noise current to the input node directly, i have try to increase the Vgs(of course, i still make sure that it is in saturation) and minimize the W/L for a required current, but it still produces near 50% of total input rms referenced noise current. what methodes or techniques you guys would take to reduce its noise based on your experiencement, please let me know, i would really appreciate it, thanks a lot!
best Regards
Nio Lin
i am a gay,who loves ppmm!
Re: how to reduce the current sinker's noise
Reply #1 - Oct 13th, 2007, 1:21pm
As a general rule, any and all current sources are big noise sources.
Consider a differenet topology, suggest getting rid of the current sources in favor of resistors (if applicable, dont know your circuits)
post the schematic for people to make better informed suggestions
jerry
Robert
Reply #2 - Oct 14th, 2007, 7:22pm
Dear Jerry,
   thanks for your reply!
   the prototype i used is illustrated as attachment, currently i used the 0.35u CMOS process to design 2.5G/ 4G TIA, except the shunt-shunt feedback structure with cascode (regulated) as input stage, i do not have other solution.
Nio Lin
