Sep 29th, 2024, 1:11pm
PSRR of Capless LDO (Read 5266 times)
msudans
India
PSRR of Capless LDO
Oct 11th, 2007, 9:48pm
I need to design an LDO which must be stable and function without an off-chip capacitor. Can I get a  PSRR > 30 dB for frequencies beyond  1 MHz?
HdrChopper
Re: PSRR of Capless LDO
Reply #1 - Oct 14th, 2007, 8:53pm
Your PSRR at frequencies above 1Mhz will mainly depend on your DC open loop gain and the dominant´s pole frequency: the higher frequency the dominant pole is located at, the better PSRR at higher frequency. In other words, you´ll need a large GBW loop.
tosei
Keep it simple
jimwest
Reply #2 - Oct 19th, 2007, 7:21pm
To Tosei,
 Usually the LDO system cannot be simplized as one-pole system.
There are dominat pole non-dominat pole and compensate zero within the unity gain bandwidth.
Among them the dominat pole is much lower than 1MHz.
So the upper limit of the PSRR determins by the distance between the zero and the dominant pole.
K/R,
Jim
lightgo
Reply #3 - Nov 9th, 2007, 5:57am
psr>30dB for all frequence?
