Sep 29th, 2024, 2:22pm
feedback problem in fully differential op (Read 2118 times)
James Bond
Oct 12th, 2007, 2:37pm
Hi, all
Recently I met a problem, I have designed a two stage fully differential opamp with cmfb, supply is 1.2V. The open loop simulation is ok, 40db gain. The input voltage bias voltage is 0.6V, cm reference is 0.6v as well. However, when I add four 40k resistors between out+ and input- , out- and input+ to  create a unity gain, I found that the dc voltage at the gate of the input pair transistors are 0.8V, and the output dc level is 1.18V. Did anybody have this problem before ? How did you solve this problem? Any suggestions would be appreciated.
Best Regards
James
MonteCarlo
Re: feedback problem in fully differential op
Reply #1 - Oct 13th, 2007, 3:21am
How about posting the circuit diagram to help us help you?
HdrChopper
Reply #2 - Oct 14th, 2007, 8:50pm
May be loading effect due to the 40K resistor? You might no have enough current driving capability in your output stage?
tosei
Keep it simple
