Sep 29th, 2024, 2:21pm
LDO compensation schemes comparison (Read 150 times)
hchanda
Oct 17th, 2007, 5:28pm
Attaching a pdf which shows two kinds of compensation schemes for LDO.
The first slide  inserts Rc and Cc for frequency compensation between the output of error amplifier and VOUT (output of regulator)
This way it spilts the poles seen at the output of error amp. and at the output of LDO.
The second slide inserts Cc for frequency compensation across resistor R1. Can you please explain how it will help in compensating the loop?
Also what are the advantages/disavantages of one method over the other?
hc
hc
hchanda
Re: LDO compensation schemes comparison
Reply #1 - Oct 17th, 2007, 5:54pm
sorry I have drawn them wrong earlier. Attaching the corrected one.
hc
buddypoor
Bremen, Germany
Reply #2 - Oct 23rd, 2007, 5:58am
The second scheme (C across both resistors) is the preferred one, however it is important either to choose a capacitor with a rather big LSR (leakage series resistor) or - to be on the safe side - to put an extra resistor of about 5 to 10 ohms in series to the capacitor.
By doing this and in order to stabilize the circuit the loop gain is a) reduced and b) its frequency response will cross the 0-db_line with a slope of about 20 dB/Dec.
(This can be easily proved in the BODE-Diagram)
Any further question ?
Lutz
