jefkat
Hi guys, I am trying to calculate the total cap at drain. The spectre output parameters (that you get after the sim) have an element called 'cdd'. According to definition this is dQd/dVd. So the change in drain charge to a change in drain voltage. If the definition is right then 'cdd' must be the total cap at the drain node. However ac sims show that actual cap is somewhat bigger than this 'cdd'. Would anyone please explain where is this comming from? has it to do with mutiterminal cap stuff (guessing)? Thanks Shaf
