Sep 29th, 2024, 11:07am
phase inversion in comparators (Read 2833 times)
vivkr
Nov 14th, 2007, 11:01pm
Please see Fig. 10 on page 4 of AN-849. What are the reasons
for phase inversion in comparators? Is this specific to technology
or device type?
http://www.analog.com/UploadedFiles/Application_Notes/46875282066493AN_849.pdf
Vivek
imd1
Re: phase inversion in comparators
Reply #1 - Nov 15th, 2007, 1:33am
It depends on the architecture of the output stage of the opamp, I think. In older (and some current also ?) CMOS opamps the output will "peg" to a supply rail (always the same) when the common-mode range at the input is exceeded.
Use a comparator if you are comparing, opamps are always much slower...
vivkr
Reply #2 - Nov 15th, 2007, 4:21am
I am not planning to use an opamp as a comparator but was just cuious as to how such a phase inversion could occur.
Are you saying that if the common mode changes beyond a certain point, then the input stage turns off and the output
is then pegged high/low depending on the output stage?
It would be interesting to see an example of such a circuit. One can always do with a list of "DON'T USE" circuits.
Could you post an example?
Vivek
Reply #3 - Nov 15th, 2007, 10:48am
This is, how shall I say it, totally unique to the transistor level architecture of the comparator.
Rail to rail common mode comparators are possible (both an NMOS and PMOS diff pair at the input, and some recombination circuitry afterwards) and all kinds of other variations on a theme.
Specifying a common mode range and operating limitations should not be a problem in most cases.
