Sep 27th, 2024, 4:28pm
Low frequency oscillator - problem (Read 5190 times)
tg
Jan 18th, 2008, 12:35pm
I have a problem with a ring oscillator. It works @ ~ half the frequency.
Its a simple ring oscillator 3*invs and 2*rc delay to get ~2MHz.
The result is far from the worstcase simulation by 30%!!!
Does anyone have an idea what could be the reason ?
Thanks.
HdrChopper
Re: Low frequency oscillator - problem
Reply #1 - Jan 18th, 2008, 6:54pm
Hi tg,
Did you check the parasitic r/C that you might have in the caps nodes you are using for the oscillator? That might be a good reason to make the oscillator run at a lower frequency and not to show up in your WC corners; unless you considered those when simulating the circuit.
Hope this helps
Tosei
Keep it simple
tg
Reply #2 - Jan 19th, 2008, 10:12am
of course, already considered, rc extraction.
Beside, the resistor been measured, its only 10% larger then typ models.
Undecided
HdrChopper
Reply #3 - Jan 19th, 2008, 6:53pm
Then I guess you are left with either a larger than expected capacitance or inverter thresholds. Were you able to check for those two?
Tosei
Keep it simple
tg
Reply #4 - Jan 20th, 2008, 3:51am
I cannot measure the capacitor because of its small size (~0.5pF).
I can ask the fab what was the vt in thier measurements, but I think such a change in vt would kill other digital and analog modules (everything works fine but this oscillator).
HdrChopper
Reply #5 - Jan 20th, 2008, 3:45pm
0.5pf sounds marginally small to me in case you are connecting it between the inverter output and gnd. If that's the case then I would double check your rc parasitic extraction...may be something not modeled in such tool. Layout visual inspection might also help.
Tosei
Keep it simple
tg
Reply #6 - Jan 20th, 2008, 7:21pm
The capacitor is connected between the resistor (and next inv input) to ground.
I dubble checked parasitics and found their added value is small, an ammount of 20fF was added to the capacitor (wires).
tg
tg
Reply #7 - Jan 30th, 2008, 11:30pm
parasitic capacitors on polysilicon resistor fingers added to total capacitance (not seen in simulation and extraction)
Issue closed
Thanks for the support
tg
