Sep 27th, 2024, 10:15am
unused emitters (Read 3560 times)
MonteCarlo
unused emitters
Jan 29th, 2008, 6:13am
What should I do with the unsed emitters in a multi-emitter npn? Connect to base, collector, Vcc or Open Circuit?
-Monte
Re: unused emitters
Reply #1 - Feb 1st, 2008, 5:03pm
As a general rule? Probably connect the emitter to the positive power rail, so that you keep the Vbe junction always turned off.
Better yet, in a chip, do a layout that only has the emitters that you need.
Re: unused emitters
Reply #2 - Feb 2nd, 2008, 6:47pm
Monte Carlo,
  What is the application, the power supply voltage of the design?
How are you using the transistor, etc. Shorting the base and emitter
should also be okay. The only concern about shorting the emitter
to the positive power supply is that for high voltage applications, the
B-E junction may breakdown and zener clamp the base to the power
supply. So for 3V applications you should be okay, but for 15V applications,
there could be issues.
Re: unused emitters
Reply #3 - Feb 4th, 2008, 12:42pm
Sheldon - good point. Hopefully he has layout freedom to get rid of the unneeded emitters.  -- Jerry
HdrChopper
Re: unused emitters
Reply #4 - Feb 4th, 2008, 2:53pm
Going back to Jerry´s suggestion, here´s one more thing to consider:
Again depending on the application, you might not want to tie the emitter to the power supply in case leakage is a problem on the NPN´s base node: although the NPN is turned off it will leak thru BE junction if temp is high.
Hope this helps
Tosei
Keep it simple
