Apr 19th, 2024, 11:20pm
Curve fitting of center-tapped inductor (Read 5899 times)
neoflash
Mixed-Signal
Designer
Mar 17th, 2008, 7:38am
Hi, folks:
I come up with a strange thing when doing curve fitting for a differential center-tapped inductor.
The original version of the inductor is a two-terminal differential inductor. I did curve fitting to find the equivalent circuit model. And the fitting seems good.
The next step I added a center-tap and got a 3-port s-parameter from field solver. The problem is when I'm doing the curve fitting again. the mutual inductance in the circuit model was forced to zero by the fitting tool. The fitting seems OK but not as good as two-port one. The inductance and Q is ok but the s-parameter related with the third port are not well fitted.
Any one ever experience same thing before? Any suggestions?
Neoflash
attached is the equivalent circuit model for curve fitting. Parameters are found by fitting tool.
neoflash
Mixed-Signal
Designer
Re: Curve fitting of center-tapped inductor
Reply #1 - Mar 18th, 2008, 5:52am
The most strange thing is that the mutual coupling between inductors are forced to be zero by fitting tool, I can't understand.
Reply #2 - Mar 18th, 2008, 9:53pm
How is port-3 treated in your fitting tool ?
Isn't Port-3 treated as ground ?
neoflash
Mixed-Signal
Designer
Reply #3 - Mar 19th, 2008, 5:41am
neoflash wrote on Mar 18th, 2008, 5:52am:
No. It is not treated as ground. Since this port will connect to a current source in circuit design. Top-biasing of current will be used.
Reply #4 - Mar 19th, 2008, 6:58am
If port 1 and port2 are drived with symmetrical odd mode,  where only differential(odd) mode is characterized,
port 3 is virtual ground.
And even if you are not driving port 1 and port2 with symmetrical odd mode, manupulation of S-parameter for differential characterization results in port 3 as virtual ground.
Or you are doing full 9 parameters S parameter fitting without invoking odd and even mode concept ?
neoflash
Mixed-Signal
Designer
Reply #5 - Mar 19th, 2008, 7:04am
pancho_hideboo wrote on Mar 19th, 2008, 6:58am:
I'm treating the 3-port network as a full 9 parameters network.
email_gz
gaoz.mail@gmail.com
Reply #6 - Mar 27th, 2008, 9:43pm
Physically,differential inductor is just a special 3 port transform (T coil) and this sharing port have no ac current pass through. so when you connect this port  to a current source , so Iac*S*(-M)=0,then just can be seen as two inductor L+M,L+M series conneted.
View Profile email_gz email_gz   IP Logged
