James Bond
Dear Visjnoe,
Thank you for you reply.
As for the 1 solution, if I want plot Vos versus temperature, I have to sweep temperature in the dc simulation, and run montecarlo simulation based on this dc setting, is that correct?
I don't quite understand solution2, I want to simulate my circuit and find out how the temperature will affect Vos(I have seen somewhere a monotonic reducing curve) , if I can model them, I already know the answer. Could you explain it a bit further?
Best Regards james
