Sep 29th, 2024, 6:25am
PSRR of an AOp (Read 3327 times)
claire
PSRR of an AOp
Jun 27th, 2008, 11:41am
I'm designing an AOp, wtih the software Cadence, and I would like to calculate the power supply rejection ratio of my ampli op. I manage to measure it, but it's not big enough, so I would like to have the formula which give the PSRR, to know what I have to change in my circuit....???
Someone can help me??
Re: PSRR of an AOp
Reply #1 - Jun 27th, 2008, 7:16pm
Claire,
  In general parameters such as power supply rejection are
dependent on the circuit architecture. So it would be useful for
people trying to help you if you provide the circuit schematic
or netlist. Also, it might be useful to provide a more detailed
description of the specification, for example, 80dB of rejection
at dc, ... Finally, it might be useful if you provided more
information such as positive or negative power supply
rejection. A little more information would be useful in order
to respond to your request.
HdrChopper
Re: PSRR of an AOp
Reply #2 - Jun 27th, 2008, 7:49pm
Hi Claire,
Sheldon is right about being a little bit more specific on what he mentioned if you want some help on this. Nevertheless - and as a very general and basic outline - the PSRR is always proportional to the (differential) open loop gain of your amplifier and inversely proportional to the gain measured from the power supply to the output.
The first one is usually the one evaluated for stability and other purposes, while the second one is highly dependent on the architecture, as Sheldon suggested.
Letīs wait for more details for a more precise answer....
Tosei
Keep it simple
midou
TUNISIA
Re: PSRR of an AOp
Reply #3 - Jul 2nd, 2008, 3:30am
hay Claire,
I want to give you a good document that will help you to design your AOp.. Smiley
but it is very large (more than 1000KB)
so, how I can help you.. Smiley
View Profile midou midou   IP Logged
claire
Re: PSRR of an AOp
Reply #4 - Jul 8th, 2008, 5:23am
Thanks for your help, I've found the answer!!! Like you said, the PSRR of an AO is high, 80 dB for mine. So, all is working very well!!!
Thanks again
