Sep 29th, 2024, 8:21am
Minimizing or reducing kickback noise (Read 1872 times)
AnalogDE
Jul 08th, 2008, 10:50am
I have a regular single stage diffamp in unity gain configuration buffering a VREF signal.  Whenever the diffamp powers on or off, it kicks back noise onto the VREF line... What are some (clever) ways to minimize/reduce this kickback noise?
Thanks in advance.
vivkr
Re: Minimizing or reducing kickback noise
Reply #1 - Jul 8th, 2008, 11:25pm
I can suggest the following which might help a bit:
1. First try to reduce any coupling between the 2 inputs in the layout, and also try and use the smallest input device that works well for you.
2. Use cascoding in the input branch to shield the diff pair from any transients in the output branch.
3. I assume that this is all on a single chip and when you speak of power on or off, this is done with a powerdown to the diff. amp. In this case, try to slow down the power on/off transient. This should be done carefully as you do not want a too slow transient either. You can also try to place the amp in a standby mode where there is still some small current in it so that it is not really off.
Vivek
